Legdoc
I have a land reclamation project that I need advice on. I have a multi phase project on my ranch with the first phase as follows.
20 acres in flood plain measuring approximately 2000' by 425'. There is a drainage ditch running parallel to the 2000' length. I want to excavate the full length of the ditch wide enough to build up to 20 acres by 1'. The excavation may get into the water table therefore a track hoe is required. The soil is black-gray clay. It is very slick and sticky so it will be a mess. The dig will be about 31,500 sq. yds. This will have to be done in a the summer as there is currently 9" of water on it. Using a trackhoe to excavate is a no brainer. The question is how do we move the spoils? Fill dump trucks? Dump it on the ground and doze it? When it is dry tandem dumps will have no problem.
Any suggestions are appreciated.
