Question for the welders
Bumpsteer
Front seat on the Struggle Bus
Mechanical designer
Been doing some shop cleanup/cleanout.
Don't recall where I got this, or why, but it's an inert gas regulator, new in the box.
What welding application would use this? Secondary side pressures are high for general mig or tig use. I'm at a loss.
Ed
2grit
Upstate NY
I cannot read the gauges well on your picture. Does the secondary gauge read as PSI or KPA? If it is KPA it would make sense because 30 PSI is approx. 200 KPA
It can be used for any inert gas but I've used that type of regulator for charging accumulators and suspension struts. That one looks a little low for the struts though. Since you just found it you likely don't have much use for it. Last one I bought a bunch of years ago ran somewhere north of $100.
lantraxco
Elsewhen
I miss the days when nothing had metric.
Amen brother... when it comes to volume and pressures... is it liters, gallons, cc's, cubic inches... and pressure.. PSI, KPA, Kg/cm3, BAR? I spend half my time converting crap to gallons, PSI, inches.....
