69zfarmer
The line filter under the cab is a horziontal small element and the return filter is a large screw on. Does both of the filters need to be changed at the same time? Does the line filter under the cab run a high pressure?
The "Operators Manual" says to use 10W-30 or 40W API-CD motor oil in the hydraulic system. Is this oil i bought ok?
