I'm looking for a skidsteer, and would like one big enough to lift a round bale of hay, push manure, and do a little digging.
Which one would fit the bill? It does need to be older, since I'm limited by funds. Prefer under 11K, but could swing up to 15K if it's really nice.
Totally new to them, been looking but not sure what to look for.
Cats are out of the question as nearest dealer is 3 hours away. Have a Deere dealer 20 miles away. Along with a NH/Case/ Bobcat dealer same distance.
A vertical lift may make some things easier but you would likely get along fine with a radial lift machine. My dad (who lives near Jamestown, ND) feeds round bales with a CASE 430. The increase in distance away from the machine does not buy you much when the load is as low as it is feeding round bales. If your using a skid steer to load out of the field and your stacking them on a trailer two bales high that may be different, but still doable with a radial lift. I would want a machine with at least a 2000 pound ROC. If your looking to spend up to 15K, here are some options. I am a firm believer in CASE skid steers so I will give you some models to look for.
85XT vertical lift. Has about 83 hp 3.9 Cummins nonturbo. They are popular here with the Farm/cattle guys. The ROC is 2650
70XT radial lift 85 hp turboed. Very powerful for its size, has a ROC of 2000.
95XT vertical lift. Awesome machine 85hp turboed and maybe over kill for your application, however if you could find one for the money you want to spend in good shape it would quite a find. This unit has a ROC with the counterweight of 3650. I have had two of them and it is like a little wheel loader.
90XT radial lift 85 hp 2450 ROC. Big and powerful, made to excavate.
The newer machines are the 400 series and not likely you will find one in your price range. However here are some numbers to look for if you found a deal.
430 radial lift 2000 ROC
440 radial lift 2000 ROC
445 vertical 2650 ROC
450 radial lift 2450 ROC
I have buddy who is a salesman and works for Titan Equipment in Jamestown if you need help.
If you are more set on staying at 11K I would find a late model 1845C. 1750 pound ROC/56 hp, argueably one of the best skid steers ever built for its time.
