Pete, The Berco part# I am showing on your machine is a CR4854/44 which is a Heavy Duty D4 excavator style chain. This chain is really common. Why did you order it from Italy. It is showing a D4D roller which is part# CR1328. I am showing your idler to be part# ID609 which is a John Deere 690B idler. Your top roller is part# CR2880. On your chain I am showing two other part#'s that would work. they are LK49/44 and CR3125/44. I am really surprised you couldn't find the chains and sprockets local. I sold 4 of the chains to the Bron Dealer about a week ago. His machines have the same problem, they wear out chains and rollers very very fast.
hi quick trax, i had a look at the invoice, part number for chain is CR6511/44
link assembly ,greased,sealed.
idler group with track ajuster and tensioner, VA299C.
what do you come up with these numbers ?
thanks quick trax, that clears it up, the idler does include the entire track ajuster. is it the split master links that make this chain so rare, as i said earlier there are none in australia. do you know what CATmachine that chain would fit ?Pete, The CR6511/44 is the sealed and greased chain w/ split master links.
The LK49/44 is the sealed and greased chain w/ master pins. My customers had a problem with the master bolts breaking so we have started leaning towards the master pin type chain on mulchers. As long as you double check your master bolts every few days you shouldn't have a problem.
Your VA299C sounds like it is the entire track adjuster and idler set up. My number was just the complete idler.
Thanks, QuickTrax
supertrack is made by a company in florida, tom king is the owner. if you type in super track on your computer you will find the web site. take my word, as i have over 15 years in mulching. for a smaller machine supertrack is the way to go
thanks quick trax for your help, it seems very few people know anything about the tracks on rayco's.The CR6511/44 chain would fit the Cat 312, B or 311, B. The link count would be different but it would fit. The Chain that would come from cat would have master pins and not master links. The next time you need chains you could go to the cat dealer and put Cat on it to see how it would hold up. The Bron dealer I deal with has done that and he went back to the Berco because he wasn't getting any more time out of the Cat chain.
The c140 has a specially made sprocket and is only available from Rayco unless you can get a ring to weld on. The problem is in the offset.Any idea what sprockets this machine uses? 23 teeth 22 bolts.
Maybe they are a Rayco part only also.I was referring to the T275. I imagine the sprockets are readily available in Europe for the original OEM machine they were designed for. My undercarriage guys are striking out here. My problem with otherwise current good sprockets is the wrong offset. They are about an inch off and they gouge on the rails.
