Forum Members, I have attached an "Elemental Interpretation Guide" for interpreting oil analysis results. This charts are to be used as a guide only.
As others on this Thread have posted, you really need multiple samples to gage the machines overall condition, as the equipment dealer or individual selling the machine could have changed the fluid(s) recently giving a healthy report. It kinda like the car dealer that always changes all the fluids before putting the car on the lot, you don't know what you got till you drive it while.
It the machine in question had several hundred hours on the the oil samples with results like this, the sample reports results would be reporting a healthy machine and lubricating system.
My advise if you buy the machine is to pull oil samples every 100 to 200 hours and trend the findings. If the wear metal start to jump dramatically and hit the alert levels in a few hundred hours, then the machine might have a system component that will be failing in the near future, and you may have time to trade the machine off or repair it before it fails.
As always oil analysis is worth every dollar you spend on it. Becoming educated on oil analysis and learning how to interpret the results of your samples are worth every minute you spend learning about your analysis program. I can email you the complete Oil Analyzers Inc. users guide to oil analysis services if anyone would like a copy. It is a good place to start learning about oil analysis and interpreting the results.
Yes please, can you email me a copy of the complete Oil Analyzers Inc.
here is my email, not sure if I can post it here?
joeeye@sbcglobal.net
Sorry I don't mean to hijack this post.... but I'd like to ask a question if I can?
Thank you for the great advice in this post, I just got my 1988 JD 310c backhoe, it has 9100 hours.... it runs and sounds very good, it was a well cared for machine. I have the complete maintenance file for the machines repair and service history records from the prior company who owned it since it was new..... so I called them to find out they used Castrol for the hydraulics and for the engine, he did mention it was the conventional Castrol 15w-40 for the engine and not the synthetic. I wish he did use the synthetic for the engine, even tho it sounds and runs good, it does have the normal typical signs that its not a new engine
....It would have been nice to have seen this backhoe engine if it had used synthetic oil all it's life to see what shape an engine with 9100 hours on it would run and look like.
I think I'll use both engine oil types, the conventional and a synthetic, and when I change the oil I'll do the oil sample analyzing to see the protection difference.
I put new synthetic fluid in the hydraulics, it did not work out well, when it gets moderately hot I get a squealing howl type noise with the loader hydraulic, and over all it don't sounds nice and tight like the sound it had before I changed it.
