farmerlund
Nice work DM. should make an awsome rig for you.
i used to run lug nut covers but when i went to change out a set of steer rubber, i found the threads out past the nuts were completely rusted off on the rh side. I likely had not taken them off for 5+ years and had forgot to remove them to coat the exposed threads. I had to replace all the studs on that side. I quit using them after thatAll those nut covers do is trap moisture and rust the threads.
Nice arse.Fenders do look better Down some
Did a hair more cut and buff on sleeper back, installed conspicuity corner tape. Not sure need reflective at rear of fenders, then now pretty well cover tape on flap straps. Did swirl mark buff some on hood and all doors.
