daewoo 220lc-iii
Hello 3rd time posting with no replies, got a excavator that drips hydraulic oil from all relief valves and seeping from a few oring locations on control valve, rear pump and swing motor, orings replaced still leaking 1gal/hr. Machine runs great just leaks bad.
What would cause the relief valves to drip oil from the adjuster screw/nut on the end?
Have been notified someone has messed with settings on pump/regular/proportional solenoid. Could this be overpressure issue?
Included pics of reliefs, leaking swing motor, pump regulator and solenoid that were changed and put back to original position
