Yes Jim, Bobcat used two different size torsion bushings and they can't tell what size was used on your machine using serial number. All you have to do is measure the diameter of the bushing that presses into hole on pintle arm to determine which bushings you have.
Pintle arms have to be removed to replace torsion bushings. You can simply use a vice and appropriate sized sockets to push old bushings out and press new ones in.
As for centering spools, depends on what type is on there now. Some of the old spools had like a chrome finish on them, they would wear over time, but were pretty hard steel. On those you can typically rotate them and rotate the bars that they contact and get many more hours. If it's the newer style spools, they wear like crazy, it's a waste of time to rotate them as they won't last that long, better off changing over to cam followers.
The pump shaft seals, pretty easy to do once you get all the control components out of the way, just make sure you clean the area well before removing the plate that has the shaft seal in it.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
