1693TA
On my 1845C the back up alarm is intermittent. I've metered out both of the pressure switches that close to initiate the alarm and they are both on the fritz. One of these is open constantly, the other closes intermittently. Never have went further than lifting wires and terminating meter leads onto the spades; then from the operator seat, stroking the hydrostat units for operation. Again, no response or state change from the one switch, and intermittent operation from the other.
Tractor is either a 1995, or 1996 build and these are "Nason" branded pressure switches. I don't know if they can be calibrated, or are just a make/break type affair. I've been told they were kind of a high failure item and am wondering if a substitute is available, or known about as I'd like to have this alarm operational again, as it should be.
Thanks,
Thanks,
