dirtworks01
Hi, We have a TL140 Takeuchi skid steer loader with 2300 hrs on it that has had hard starting, rough running and idling issues in the past. I went through and replaced the main fuel line from the tank to the water separator, then replaced the electric feed pump and associated lines. Changed out the fuel filters and checked remaining fuel lines. I also adjusted the valves. The engine now starts and runs great at all throttle settings including full governed speed. As soon as you load the engine it bogs badly and in the worst case will stall out all together. I have bled the injector lines multiple times and seem to still keep getting air bubbles from them. I must still be getting air from somewhere.
Has anyone had a similar issue with their takeuchi's
Thanks
Dirtworks01.
Thanks
Dirtworks01.
