oceanobob
For those tight space jobs, the smaller minis under 5k pounds sure save a lot of handwork. On our 700 hour Kubota U17 (narrow/wide track machine), occasionally one track or the other gets loaded up and the drive motor wont move the track: usually one direction is affected more than the other. Swinging the house and lifting the track and some operation of the track in the air clears it. The soil moves out of the track in a turn or so of the track and all is good.
Note: This is not due to counter-rotating the turns which would cause this issue certainly. Could occur simply by driving parallel along the toe of a spoils pile. Compacted sand never a problem but loose sand (such as during a job) will be the precursor.
The latest event was up against a fence corner and this track stoppaged happened .... couldn't get the track lifted to reduce the load and clear it. Ended up using the arm to pull the machine away from the fence and made a mess in the work area. Previously to this occurance had the machine in the five foot setback tween the house to the fence .... thankfully it didnt occur at that location.
In my JD450G dozer manual, the track tension is to be adjusted by the operator based upon soil loading. Havent read this about the rubber tracks and not wanting to experiment and risk a track jumping off if I try to loosen. A Cat mini we rented on occasion had a tendency to pop off the track regardless of care when doing turns but the mechanics said the track was worn beyond the replacement schedule and they convinced the management to send the machine to the auction. They pointed to the rubber track design and said the inside typically wears before the exterior and should be replaced. Which was an OK explanation because we try to take care of equipment - regardless of who is the owner.
Could be this issue be a characteristic of these smaller machines? Should I dare to consider loosening the track? Dig with the blade opposite the bucket?
***Using the blade to raise one end of the machine is not sufficient to allow the track to spin. If the blade is opposite the digging, well, yes this could be a suggestion to lift the machine - blade and the boom opposite. Usually find myself digging with the blade at the same end where the bucket is....maybe this is a solution for soft dirt operations?
