GuglioLS
Frank,
Thanks for asking. I will try to help answer some of your questions. First the ROPS, The uprights are 3" X 1/4" wall hollow square tubing. I have one pic for now, and will get you some more as soon as I take some close up's, re-size and upload them. Give me a couple of days to do that.
Adding a valve like I did involves removing the floor plate, Seat, seat plate, rear plate between the hydraulic and fuel tanks. Then remove the soft line and hard line from the hydraulic pump all the way to the control valve. Install a Open center valve with ~ 20 GPM capacity and 3/4" in & out ports somewhere like mine Then get two new hoses made up, with Komatsu JIS 22 mm x 1.5 mm metric female 30* cone seat fittings on one end and 3/4" pipe thread on the other. One end connects to the hydraulic pump, the other to the IN of the new valve, from the OUT of the new valve to the IN of the OEM blade control valve. To get hose lengths use some old garden hose routed through the system to get the lengths just right.
Larry
Larry
