sick&tired
I didnt get any replies to my earlier post, so i just went out and started working on the D31s.
I took the floor board off, i took the seat off, and the rear upper panel. I had cleaned it with a pressure washer before, but didnt have real good access in the trans area. I am going to rewash it today.
What i found was the lever which engages the steering clutches on the R side was stuck completely in the up/on position. It was rusting, and being prevented from returning by alot of hard packed dirt in that area. I took a big screwdriver and was able to scrape out alot of the dirt and clear the blockage. Then i sprayed bunches of WD40 on the joint and let it soak for a few minutes. I took the screwdriver and a hammer and started to bang on the lever to loosen it up. After about a 1/2 hour of tapping down, stepping on brakes clutch etc. I was able to finally break it free and now it will move smoothly and return where it is supposed to.
Hoping that i have fixed it somewhat, i started the tractor, let it warm up, and without replacing anything i removed, i faked a seat and tested it out in my driveway. Seems to work better now. I didn t experience the dragging problem- so far, and now it turned on R side like it was supposed too. I adjusted the brake pedal linkages a little, i think i need some more. I dont have the repair manual yet so im unsure of the exact proceedure. Anyone have any pics of what linkages i should be adjusting on the brake rods?- there are a few on each one. Darin Ray where are you buddy? You seem to know the most about these kommies.
Thanks
S&T
Thanks
S&T
