Service Manual Trading Post
fishfighter
Louisiana
Looking for a good service manual, operators manual for a 1979 Case 580C that is on a disk. Bought one off ebay that sucks and is useless.
troyharnish
Still looking for a service manual for a Case 580 Super M, series 2. If someone has one as a PDF, I can arrange a place to upload it to, and I would be happy to contribute something for your trouble ;)
newtodirt
saskatchewan
I have NH LS160 & 170 Service
Bobcat 310&313
Ford 550&555
JD 3640
Mack Truck Series 8
I'd like to trade for some excavator manuals.
Bjarn
I am still looking for a Komatsu Model PC50uum-2 shop repair manual.
It seems there are plenty of PC50uu and PC50uu-2 manuals, but no PC50uum-2. I did find one at http://www.komatsupartsbook.com but is in Japanese only. What is the difference between the PC50uu-2 and PC50uum-2, how close are they??
Thanks
Bjarn
scheirerequip
Pittsburgh pa
equipment and truck repair business owner
Hello everyone I need 3046t. Cat. Engine overhaul manual I have all case tier 3 manuals plus all cat on highway c9-15
Thanks
Yamaha
Eastern Ontario
Hey everyone, I would love to get my hand on a service manual for a 1976 Mf50a if you have something shoot me a pm
Thank
DucTrip9
United States
Project Manager
Hi All,
I am working on my 1973 JD 410 Backhoe/Front loader replacing hoses and cylinder seals. I just replaced the outer o-rings on the hydraulic pump and realized the hyd. pump solenoid was not wired to the starter solenoid....time to start reading a manual. If anyone haas an early 70's JD 410 backhoe manual, I have a need. THANKS.
trini_fella
Trinidad and Tobago
OK send me PM with email add and I will send to you not sure if the forum will allow me to attch it here. I am new member other forums may allow it so all members can get the manual if they need it
Hey about to PM you as well, hope you're still around. Looking for any manuals for the 428C I can gather, until I can save up enough to purchase the service manual itself, which i will be more than happy to share the knowledge :)
My serial number is 2CRO2989
rowdygator
colton, oregon
MrKomatsu, i have a Lc150-3 i need a readable manual if you got one im having a starting issue with it and mainly nee a wiring diagram. hers what happened , it was being used and when it was shut down and the smelled a strong burning odor and some wires were burnt around the starter, so i pulled the starter and you could tell it was burnt up so i bought a new one well the new one came with a wiring connection connector coming from a small like selliniod that my old starter didnt have on it, any thing that could help or advise to fix this thing would be appreciated.
twisted235
Bath ny
driver,operating engineer
starter
I just bought a new starter and had the same question .if you put a spade connector on your wire to the solenoid. Hook it to the black and white wire it should turn over.
rowdygator
colton, oregon
Twisted235 , so i dont have to run a ground wire fron the green out of that connector, just hook a spade to the black and white wire of the connector???
twisted235
Bath ny
I just hooked up into the bw wire and it worked.i believe the gr wire goes into the nuetral safety circuit but my d21s-3has a different wiring.setup.It sounds like your machine has the same problem as mine.The starter switch or relay is staying on I am also installing a battery disconnect switch that can be reachedfrom the seat in case it happens again.
