Service Manual Trading Post
#VKMW00223 confirmed. The oil seals I mean to address are on the Turbo oil inlet line(banjo) and oil outlet(tube) I hope that makes more sense, Thank you sir
All clear now. See if the attached file contains all the information you need. FYI there are no serviceable parts in the turbocharger, at least not from Cat.
  • Turbo Gp.pdf
SR220noob
Can someone please share the Operators manual for a Case SR220? Parts catalog too if you have it. Already have service manual. Searchable format would be great but I'll take anything. Thanks!
jdch
ohio
I have a number of manuals for sale bought at auction from a local retiring repair shop. Most are in very good to like new condition. I have some (mainly Cat) in pdf as well as paper, some only in pdf and some only paper. Prices listed are asking, and do not apply to pdf.
~John
Cat
Cat Service Manuals (yellow soft cover type - $50/ea)
D4C 39A/40A
D7C 17A
D7E 47A/48A
D8D/E 14A/15A
D8H 35A/36A/46A
D9D 18A/19A
D9G 66A
Hydraulic Controls
Cable Controls
922 Traxcavator 94A
933 Traxcavator 42A
944 Traxcavator 49A
955 Traxcavator 60A
572 Pipelayer 21A1
583 Pipelayer
613 Scraper 38W/72M4268+
619 Tractor 89E/90E
619 Tractor 61F/62F up
630 Tractor 52F1
631 Tractor 51F1
DW15 Tractor 59C/70C
DW20 Tractor 57C/67C/87E/88E
DW21 Tractor 58C/69C/85E/86E
No 12 Grader 99E
No 14 Grader 35F/96F
D311 Engine 51B
D326 Engine 39B/ 40B
D330 Engine 56B/57B
D337 Engine 37B/38B
D339 Engine
D/G342 Engine 31B/32B/49B/50B
D343 Engine 62B/33B
D353 Engine 46B/47B
D/G398, D/G379 Engines 66B/67B/68B/69B
D/G397 Engines 41B/42B
1673 Diesel Truck Engine 70B
Gas Engine for 944 Traxcavator 58A
Marine Gears
Torque Converters
Rack Setting Charts
Cat hard cover binders ($150/ea)
920/930 Wheel Loader 41J/41K/62K/75J/79J (3304/3306 Engine)
920/930 Wheel Loaders 41J/ 41K/62K/75J/ 79J (D330 Engine)
950 Wheel Loader 31K/43J/73J/81J
Cat Serviceman's Reference ($35/ea)
D2
D4 Tractor 4G, 7J, 2T & 5T Series
D6 Tractor 4R, 5R, 8U, 9U Series
D7 Tractor 7M & 3T Series
D8 2U Clutch & Trans Service
No. 27, 25, 24, 23 & 21 Cable Contol
DW20 Tractor
D311 Engine
D318 Engine
D8800 Engine
D13000 Engine
Rack Setting Chart
Fuel Injection Pump Housings
Diesel Engines (1941)
Parts ($25/ea)
D2 3J
D2 4U
D2 5U
D4 7J/2T
D4 7U
D4 6U
D4D 82J
D4D 78A
D5 SA 98J
D5B SA 26X
D6 9U
D6 8U
D6C 10K
D6C 17R
D6C 74A
D7F 92E
D8H 36A
920 Wheel Loader 62K
930 Wheel Loader 73U
930 Wheel Loader 41K
950 Wheel Loader 81J/31K
922 Traxcavator 94A
922 Traxcavator Gasoline 63A
977L Traxcavator 11K
3304 Vehicle Engine 78P
3304 Industrial Engine 4B/5BA/5CA
Operators/Misc ($25/ea)
D4,D5,D6 Direct Drive Operation
D8H 22A/35A/36A/52A Op/Maint
D2 3J/5J Operator's Instructions
D6 2H Operator's Instructions
D4 4G/7J/2T/5T Operator's Instructions
922 94A Wheel Loader Op/Maint
920 & 930 71H/41J/75J/79J/41K/62K/73U Wheel Loader Operator's Guide
966 75A/57A Wheel Loader Op/Maint
No 12 99E Motor Grader Op/Maint
Cat sales flyers/books ($10/ea)
Cat Diesel Engine Selection Guide for Truck & Bus Drivers
Cat Batteries
D6D SA
621 Scraper
936 Wheel Loader
3306 Truck Engine
3208 Intercity 185 hp
3208 200 hp CA
3208 175 hp
613 Elevating Scraper
627 Scraper
657B Scraper
666B Scraper
651B Scraper
660B Scraper
Cat 930,950,966C, 980B Wheel Loaders
D10
631D Scraper
3306 245 hp
3306 270 hp
3406 380 hp CA
613B,623B,633D Elevating Scrapers
Cat product line
DD9G
I&T Manuals (aftermarket, sort of like a Haynes/Chilton's for tractors)
Hardcover 1948 I&T Shop Book $150 - covers:
Allis Chalmers- B,C, RC, WC, WF
B.F.Avery - A & V
Case - C, CC, D, DC, DO, L, LA, R, RC, S, SC, SO, SC, VC, VO, VA, VAC, VAO
John Deere - A, B, D, H, M
Ford - 2n, 8n, 9n
International Harvester - A, AV, B, BN, CUB, F12, F14, FW12, FW14, F20, F30, 1020, H, M, HV, MV, 04, 0S4, W4, 06, 0S6, W6, 012, 014, W1`2, W14, W9, WR9, W30, W40, WA40
Massey Harris - 20, 20K, 30, 30K, 44, 44K, 44(6), 55, 55K, 81, 82, 101JR, 102GJR, 101, 101 Super, 101SR, 102 GSR, 102JR, 102SR, 201, 202, 203, 203G
Minneapolis-Moline - GTA, R, U, Z
Oliver - 60, 70, 80, 90, 99
Service Manuals - $25/ea
AC
WD-45 diesel engine & accessories
D-14
D-15
D-17, D-17 series IIII
D-17, D17 diesel
D-19, D-19 diesel
180,185,190,190XT,200,7000
D-10,D-12
Ford
2000,3000,4000 (3 cyl) pre 1975
5000,5600,6600,6700,7000,7600,7700
501,600,601,700,701,800,801,900,901,1801,2000 (4 cyl), 4000 (4 cyl)
2N,8N,9N
5000,5600,5610,6600,6610,6700,6710,7000,7600,7610, 7700,7710
8000,8600,8700,9000,9600,9700,TW-10,TW-20,TW-30
JD
3010,3020,4010,4020,5010
1000,2000,2510,3000,4000,5000
3010,3020,4010,4020,5010,5020
3010, 3020, 4000, 4010, 4020, 4320, 4520, 4620, 5010, 5020, 6030
J.I. Case
D,S,LA,VA
730,830,930
770,870,970,1070,1090,1170,1175
1270,1370,1570
1190,1194,1290,1294,1390,1394,1490,1494,1690,1594
IH
706,806,2706,2806
TO35,TO35 diesel,F40,MH50,MHF202,MF35,MF35 diesel,MF50,MF202,MF204
MF1100,MF1130
MF1080,MF1085
Massey Harris
16(pacer) sn PGA 50,000+
21(colt),23(mustang),33,44 special,55 (sn 30,000+)
20,20K,22,22K,30,30K,44,44 diesel,44K,44LPG,44(6),55,55K,55 diesel, 55LPG,81,82,101,102,201,202,203,Pony
Cockshutt
20,30,40,50, CO-OP: E2,E3,E4,E5,Gamble's Farmcrest 30
540,550,560,570
Oliver
1550,1600,1650,Cockshutt 1550,1600,1650
1750,1800(A,B,C),1850,1900(A,B,C),1950,1950-T,Cockshutt 1750,1800(B,C),1850,1900(B,C),1950,1950-T
Standard units & engine suppliment to SU-1
Standard units spec manual
Flat rate (time) manuals - $10/ea
AC
B,C,CA,D14,D17,D17 diesel, G, RC, WC, WD, WD45, WD45 diesel, WF
B,C,CA,D10,D12,D14,D15,D15 diesel,D17,D17 diesel, G, RC, WC, WD, WD45, WD45 diesel, WF
Ford
2000,3000,4000 (3 cyl), 5000 (1965+)
JD
J.I. Case
200B,300B,400B,500B,600B,700B,800B,900B,430,530,63 0,730,830,930,1200
IH
140,240,330,340,424,2424,460,560,656,660,404,2404, 504,2504,606,2606,706,2706,806,2806,1206,21206,B27 5,B414
Cockshutt
540,550,560,570
20,30,40,50,E2,E3,E4,E5,30
Case Parts Manuals - $20/ea
310 Utility Crawler
310C Utility Crawler
310D Ultility Crawler
310G Crawler SN 3032301 (1967) up
310G Crawler SN 3032301-3039619
450 Crawler Before SN 3038436
356 Terratrac Crawler
400 & 500 Terratrac Crawler Before SN 3004242
420 Terratrac Crawler SN 3008188-3012300
420B Terratrac Crawler SN 3012301-3014316
420C Crawler
520 Terratrac Crawler
600 Terratrac Crawler
930&940 Ag Tractor
Model C Tractor Inc 'CO' Vineyard Special
Model L Tractor
Model LA Tractor
Model LI Tractor
Model SI Tractor
V Series Tractor
VA Series Tractor
VAI Tractor
VAS Tractor
Model DE Engine
Model LAE Engine
Model SE Engine
Model VAE Engine
Model 188 Engine Diesel & SI
Model 219A Power Unit Air Cooled Gasoline
Model 319 Engine Gas/LPG
Model 377-G (Gas/LPG) & 401-D (Diesel) Power Unit
Model 400 Power Units (409 Diesel, 419 Gas/LPG)
Model 509 Diesel Engine
Model 600 Power Units (609 Diesel, 619 Gas/LPG)
Model 900 Power Units (909 Diesel, 919 Gas/LPG)
A284 SI / A301D Diesel Power Units
320B/420B/420BD Industrial Wheel Tractors
530 CK Tractor
530 CK Tractor
580 CK Tractor
580 CK Tractor
580B CK Shuttle Trans
310B, M420, 430, 440 Forklift
530 CK Forklift
530 CK Forklift
580 CK Forklift
NT Twine Baler
NAP-3 Baler
177 Hay Baler
Corn Harvesting Attachement for C2 Forage Harvester
Model 200 Forage Harvester Suppliment
Model 211 & 221 Forage Harvester
C2 Quick Attach Forage Harvester
Case Detroit Highway Mowers
434C & 444C Corn Planter
2 Row Listers for DC & SC Tractor
Spike Tooth Harrow Model BE, CE & USE Series
Model 10, 20 & 30 Tool Bar
Model 20 Drop Hammer
K Series Toolbars & Planters
Model 75 Combine
Model 1000 Grain Combine
Model 1010 Combine
Model M-2 & K-2 Combine
F34 Corn Heads for 120/150/600/800/100D Combine (prior to SN 8227901)
F345 Corn Head for 600/660/700/800/900/960/1000/1010/1060 Combine (after SN 8227901)
Model 840 Windrower (prior to SN 8151601)
Model 850 Windrower
Model 950 Windrower (after SN 8292501)
Model 950 & 1050 Windrower
390 Series Loader (391 & 392)
Model 22 Loader for 430 & 440 Tractors (after SN 4062588)
Model 26 Backhoe for 480CK, 310G & 450
Model 26 & 26B Backhoe for 480CK, 310G & 450
Model 32 Backhoe for 310G, 450, 750, 1000D, 1150 & W
Model 32 & 32S Backhoe & Model 32 Loader for 530CK
Model 33 & 33S Backhoe & Model 33 Loader for 580CK
Model 34 Backhoe for 680CK
Model 35 Backhoe & Loader for 580B
Do you still have a service manual for Case 1494
SR220noob
I need electronic, hopefully searchable manuals (operators, service, parts) for a 1990 Cat D3C dozer. Thank you. skiraly at gmail.
Pandasick
Michigan
Hello. I am looking for manuals (operators / service / parts) for a 1992 Case 590 Turbo backhoe.
I would greatly appreciate it if anyone was willing to share!
BillyEv
Michigan
JCB 210S II Parts Manual. Hello, I bought a JCB 210S II this year. It DID come with a manual. However, the manual is missing the single page I actually need for the latest repair. Any chance you can scan in a page or two for me ? My parts book is "JCB Publication 9800/8842, Issue 4". I'm missing PAGES 343,344. Which is chapter F2-3-3 to F2-4-2. "Hub and Components".
I can scan in a chapter for people as well, if that helps.
tool_king
new jersey
road mechanic owner
I have the service manual in pdf I can send you . What is your email ?
Benkel
Florida
I was trying to familiarize myself with the forum link. I’ new to it My email is [email protected].
2014 Case 580SN.
My major issue now is the entire hydraulic system stop working after 4 hours of operation.
I waited 5-10 mins then it start working again. I really would like to have this resolved .
Thank you.
Cat308
Lithuania
Hi all repair service manuals for all brands of heavy machinery I got my manual for cat 308 good manual for a price I hope it will help someone
Mebaad
Arkansas
Hey Guys
I just purchased a 2014 JD 232e Skidsteer, Had an electrical issue with relay K8 that i found a post on this site and got me back running.
I need any manuals i can get my hands, Greatly Appreciated.
ozarkag
ozarks
Looking for electrical wiring diagram or service manual for a New Holland C238 JA0C238EFM410165
Thank you, Pm if you need email
The Service Manual is SENR3800 which includes the /Operation & Maintenance. AFAIK genuine OEM manuals are only available in paper or CD, not downloads. See this one on eBay. New I imagine it would be close to $1000.
Parts Manual is SEBP1775. Again available in paper or CD but can be downloaded from HERE by putting SEBP1775 in the box and click Search.
