Should you grease if the backhoe sits?
emmett518
USA
If the backhoe sits for a period of time, should you grease if you haven't dug with it?
emmett518
USA
Any advice for dealing with joints where the grease only oozes out from one area and not the entire joint?
Rotate the pin then grease the other side
Sorry I should have said rotate on the pin mean cycle the joint - move the boom or bucket which will allow you to grease other places on the pin if you want. I just grease in whatever position is comfortable to get and let go back to work. If you're greasing regularly the pin will be coated.
Like an excavator turntable for example. Our Cat's have a grease fitting and a line 180 degrees on the opposite side of the turntable. Grease one side then rotate the house 90 degrees to grease the other quandrants.
