I may have missed it, but what kind of dozer are you using? Sounds like you and I are in a similar situation wanting a decent, smaller pull type scraper.Thanks. I have some roads to make and a creek to bridge on our family property that is very hilly so don't want to enlist an end dump and certainly don't want to push dirt that far. I think a pan would serve to lessen the hillside roadway incline by scraping some near the top, and filling closer to the bottom. The process is reversed once across the creek at the bottom.
Like you I've looked for used and haven't ran across anything fitting the size I'm looking for. Many are high priced and need a lot of refurbishment for what is asked. I'd like to have one about 8ft. wide so it could be pulled without a permit when moving distance, and match closely to the dozer.
In good conditions a wheeled tractor is quicker and cheaper, but when the conditions get tough a crawler tractor will excel. Steep ground, soft ground, hard pulls, etc. Hence my desire to have a scraper sized to both my dozer and farm tractor.It would seem that using a dozer to pull a scraper would be slow and expensive per hour. More of a question than a statement, I have no experience with it. There are quite a few guys with pans leveling fields here for flood irrigation. So while I don't do it, I see a lot of it. Most use Steigers pulling large pans, and MFD tractors pulling smaller pans.
Yeah thats a lot more tractor than I’m working with. All the scrapers we’ve been discussing would turn into a pretzel behind a crawler tractor that size!I have a Fiat-Allis 11B tractor. This was a direct competitor with the Caterpillar D6C, and International TD-15 series when new in 1975 as I understand:
Appreciate your input and to be honest, I don't get along with running "junk" very well at all. Just me. If I drag something home that is loose I can line bore and weld it up for correct operation if the project is deemed worthy. I have that setup and most tooling needed adding to it when needed.Depending on how you can handle running junk, "almost worn out" will do a whole lot of work compared to the typical newer tractor scraper, and stand up to a dozer that size, rather than "pretzel".
Probably not if you'd be fixing everything. Running it yourself is a little different, you don't have to worry about an employee pulling it apart with the dozer. If you're the only one that will use it with the dozer, you can be a little more careful.Don't know if something I should pursue or not... The paddles are worn ...
