Maxxum5120
When the red light on the emergency stop switch on the platform is on, everything is fine.
If you then go all the way down, the light goes out after approx. 3 sec. Then it will do everything, but won't go up further than 1 to 2 meters.
If you go all the way down with the light on and then go back up a little bit, the light stays on.
The light at the bottom near the ignition switch always stays on.
The batteries have just been replaced.
When operated near the ignition switch, it always goes all the way up.
Where is something going wrong?
