I've little/no experience with dozers, but am interested in finding a used one, with a max operating weight of around 16-18k lbs.(The largest I could carry on my trailer.)
Other than the obvious concerns about undercarriage, and other mechanical wear, what would you look for in a used dozer? What to stay away from?
What is the smallest size that will still push over smaller trees (4-6"at base)?
I'm looking for specific good older models/brands and perhaps the problematic models too avoid.
Right now I've been leaning towards an older JD450, but am open to suggestions.
6-way a must?
Hydrostat good or bad?
Is 8800 lbs too small for real work?
Any good models that seem to sell for less than the rest?
I don't mind if it's old(suprise ) as long as it's still serviceable, and of a design that is as easy too work on as possible for a dozer. That second part scares me about the 450. I've been told the clutches are buried pretty deep in the case, when repair is needed.
Thanks!:notworthy
6-way a must?
Thanks!:notworthy
