some wabco pics
scraperboy222
australia
operator/trainer
hi all just a couple of pics of some tractors we used to run here in oz
td25c
indiana
Great pic's. I like the 222H,It look's like it has the electric drive motor's on the chain.I have a Wabco C pull self loader.Dose the 222 have a torque converter behind the engine?My C pull has a clutch and 5 speed tranny.
scraperboy222
australia
operator/trainer
The 222 had the alternator staight off the rear of the engine then the tourque convertor/transmission unit bolted to the rear of that.trans was a 5 speed semi auto
single electric drive elavator box.
Buckethead
Waterfront
Operator
The one in the bottom pic looks like a Michigan
The one in the bottom pic looks like a Clark Michigan 110, not a Wabco.
scraperboy222
australia
operator/trainer
It is a clark 110-15B same tractor thats on the float in a earlier pic we used to run it as well down here.
td25c
indiana
Wabco's & clark's,bothe fine machines.Thanks for the pictures scraperboy .
Gord229
Canberra, Australia
Operator
Hello Scraperboy222
The 222H looks fairly new in the photo. Do you still own/run this baby?
I made a mistake late the year before last and bought a 623E Cat instead of one of these. I have regreted my decision ever since. it has cost a bundle to keep and the problems seem to never end.
I own a 229F and have for more than 10 years. She, in comparision has cost vey little in terms of breakdowns and has a very good reputaion around town as one the most reliable scrapers available. I love operating it!
Cheers
Gordon
scraperboy222
australia
operator/trainer
hi Gordon
the 222H is a 1985 build from memory the photos were taken in 2005 just before it was sold that was a sad day. was a very nice machine to operate i have only seen 1 229F it was at Morven up here in QLD about 8 years ago i have not operated one of these what are they like?
Cheers
Bevan
Gord229
Canberra, Australia
Operator
Bevan - thanks for the info on the 222H. Sorry to hear you had to part with it.
As for operating the 229F, it is a lot of fun. They are a very well balanced machine and you have to work hard to drop the nose. I enjoy showing up the Cat boys by going places they can not go. For example, with the very low centre of gravity and width on its side, you can cut a 2.5 to 1 batter (as long as you are careful not to overload the bowl and have a good exit route). The best I have ever done with a Cat is 3 to 1 and that's frightning.
The old girl looses it a bit on long hauls as the Cats have a better top speed but at the end of the day I am usually only down 2 or 3 loads.
Not bad for a machine which has just celebrated its 40th birthday!
Heres a couple of shots of it at work here in Canberra a couple of years ago.
Cheers
Gordon
scraperboy222
australia
operator/trainer
Hi Gordon thanks for the photos looks like a very tidy machine.My dad started out in 1973 he bought a 10E2 drove it home from brisbane 1100km through toowoomba 5pm friday afternoon not sure how this would go these days he then traded up to 111As all second hand bought a new 101G in 1979 which we still have several other scrapers bought and sold over the years 101Gs 110-15B clark before getting the 222H.
Bevan
frankderrico
wisconsin
Scraperboy222, did you work on your dads 111A's very much? I'm having trouble with mine,:Banghead maybe you could help. Hope so.......Frank in Wisconsin:usa
bigrus
Southern Queensland Australia
Joystick attendant
More little Wab's in OZ
A 34 year old scraper operated by 50yr "young" operator ;). Still enjoying shifting dirt.
bigrus
Joystick attendant
A downside to the H
hi Gordon
Cheers
Bevan
A fellow contractor had a 222H from new. 12000 hrs & no engine rebuild either, (the trick- oil change every 100 hrs filters & oil again & 200 hrs)
The only downside was the hitch cracked & needed exchange EVERY 450-500hrs :eek: Apparently the H's were 1' longer than the G's. This was the only reason deduced for causing the problem :(
Does anyone else have a similar story on the H as there were a few around here that suffered this problem (was a warranty job till the dealer decided to find an "opt out" reason) :mad:
