- Joined
- Jan 21, 2007
- Messages
- 15,977
- Location
- Alabama
- Occupation
- Running what I brung and taking what I win
Transportation is a very regional thing. What a man can haul in Iowa where roads are arrow straight and flat as a skillet is completely different than here in the mountains with 20%+ grades and sharp switchbacks. Most of AL I've been in is somewhere in between.
Around here a 120 is about the biggest hoe you'll see behind a tandem/tri axle dump truck, lots of 8-9 tons. Even a 160 most guys are hauling with a semi and either a short rgn or a tandem/tridem pintle hitch trailer behind a semi tractor depending on how tight of roads they have to get down. Finding a safe spot to unload and turn around can also be a challenge. There are some sites that are just inaccessible to a 210 size hoe and 336 and up are relegated to work in town or sites with main highway access.
All that being said, I understand and agree with your logic. We just have to scale everything down a bit, hence my interest in the 10-12t class. A 5-6t hauls nicely behind a medium duty truck, 8-9t is better behind a tandem and at that point you might as well haul a 10-12t.
I was talking specifically about our operation as far as a lowboy goes. I could haul a 310 sized machine with our L9000 and tandem tag but I'd have to pack a lunch if the move is over 10 miles, cheaper to hire it moved.
Tight sites are where the Landoll our lowboy service has shines. Being able to slide the axles empty and maneuver a tight turn is extremely handy. One of those trailers are well over $100K new so it's cheaper to hire out.
In the past we've moved 315's behind a tandem and tri-axle dumps with the trailer we have now. Worked great.
