A few weeks back the tilt function on my Case 450C dozer stuck in one direction. You physically could not push the spool valve in the other direction, only neutral and tilt to the left. Took it apart by sliding the offending spool up and out of the valve block and sprayed some brake clean and compressed air down through the bore. It seemed to clean out whatever was in there although I never found the piece of dirt/metal. It did put a little nick in the edge of the spool but I cleaned it up with a file and all seems to be working fine.
Question is how should I prevent this from happening again or was it just a freak thing? Every hose on the machine is new but the steel lines are original. I'm guessing it could have either been a tiny fragment of wire from the new hoses that I missed or a bit of dirt from the existing steel lines. My thought is either leave well enough alone and run it, worst case I have to pull the spool out again, or flush the lines and risk dislodging whatever may be far enough down the lines that it's never going to get to the cylinder or valve anyways. If I flush it I could either pull both lines off the cylinder and pump some amount of oil through the lines into a bucket or connect the two lines together and just hold the valve in one direction to move a large volume of oil through and back through the filter. The spool I'm working with is the last in the stack and dumps directly into the tank return filter. Whats everyone's thoughts?
PS I'm posting this here instead of the dozer section because it's general hydraulics, not necessarily specific to any machine.
