oceanobob
Regarding a JD 450G w around 2700hrs. Sprocket showing obvious wear. Pins still in spec with a little egg shape. Rails look decent, also in spec. No bad rollers. Grouser pads pretty good. Might need to repair/rebuild the tensioners as one side leaks to a certain point after tightening with the grease but then in an hour or so is back to a little looser than desired.
Original plan was to turn the pins. The cost of this including fuel to drive there and back twice isn't too far from new import rails and most say the best plan is to run to failure. But what does this mean? Cause this would mean the sprocket will be soon to be skipping and jumping.
What about this idea: has anyone heard of sprocket inserts? These reportedly would weld into the teeth and maybe would allow all the items to last a little longer and then replace all the parts at once. Work demands for the machine have not resumed the pre 2007 levels. But on the other hand, the machine is fully paid for.
