May need a recharge, the mb800 needs a flow 22-30 gpm at 1800 psi to work, also the machine hydraulic flow may need some checks as well. Since you said it runs slow, there are some causes, low hyd flow/check system, excessive heat build up/oil cooler/releif valves/use lower throttle setting, excessive nitrogen pressure/ de-gas and recharge, then internal leakage/check seals and orings. I would find a rental yard that has the test equipment and have it charged, stanley sold kits to do this, you have three charging areas on most, high pressure accumulator/ nitrogen chamber/ low pressure accumulator. And yes they do need a recharge, we kept ours chained off the ground and uprite when stored.
