Starting 299d2 after fuel/water separator repkacement
Thinking I might go ahead and tackle draining and flushing the tank. Any suggestions on process?
I thought you had an O&M Manual.? Process is fairly simple. Get the fuel level pretty low, locate the tank drain underneath (it will be in one of two possible locations), park the machine overnight with the tank slightly inclined towards the drain location, then remove the drain plug carefully. Be prepared with sufficient containers to catch whatever is in the tank.
ColdBlackWind
Trigonia, Tn.
Yes sir. That gets it drained but it needs a good flush after that.
