Stuck cab bolts NEEEEED HELP!
I still have 6 bolts in the bed to remove, and I think Ill heat them up with the propane torch first to make sure they want to spin, if these were to strip, there is NO way to get them off the way I got these out.
Hello JD4020,
Heating the bolts will actually cause them to get tighter in the threaded hole,
because they will expand. This can work to your advantage though.
Heat them, and they expand against the hole... usually expanding it a fraction
too, also, and probably the most important... it helps break the rust and crud loose.
I would not attempt to turn them if they were hot because the threads
will seize or gall... and the heat weakens the bolt so you might even twist the head off.
Try letting them cool first... and then a good twist.
If that doesn't work, heat them again and gently try just rocking them back and forth... just a little... while hot, with a wrench....
Sometimes turning them the wrong way... just a bit... even helps... then back to cold before a bunch of power.
Of course, it's best if you can heat the bolt hole, so it expands... but that might not be possible in your case... just be carefull... or you'll have to use a hard-out on all of them.
OCR
