Good day,
I’ve an older (80s model) compressor that stalls when cold. To allow the machine to run, I’ve got to crack open a hand valve to take the load off the compressor. Once everything is heated up (15 minutes or more) I am typically able to close the hand valve and the compressor will run and maintain pressure at idle.
There’s some fiddling that’s been done to the throttle / governor linkage as the motor was replaced with an “iron duke” and the intake is on the opposite side as the original motor. Fuel flow and pressure are good.
My main question is this, as I’ve never fooled with a large engine driven compressor except for this one. Is typically there a clutch that disengages the motor when set pressure is reached? There are some pilot lines that run to the bell of the air end, and seem to sit behind what looks like a clutch, but if it is a clutch it certainly doesn’t do it’s job. I cannot find and technical information to this compressor online.
