koselig
Hi all!
A few rookie questions about operating our SVL75-2 with a Kubota snowblower.
Firstly, I had the hydraulic lines disconnected (and had released the pressure before disconnecting by pushing in the connectors) and they leaked on the shop floor. Is there a standard practice to avoid this?
Secondly, the dealer has the lines tie wrapped together so I'm unable to use the hose routing guide on the load arm, and this puts the smallest line under a lot of tension. This seems wrong. Should I cut the tie wraps and route the lines better myself?
Thirdly, the snowblower has an adjustment to set the speed of the main auger. When I got the snowblower, the main auger was not turning at all. I found this was set at 0. The instructions state "Rotate knob to a higher number to decrease auger speed and to a lower number to increase auger speed". My experience (no auger movement at 0) seems to contradict the instructions. Moving it to about midway, as shown here, resulted in the auger moving and all functions working as expected including spout. What should this ultimately get set to, as a first try to be ready for the massive Lake Superior highlands snow season?
thanks everyone!
Patrick
thanks everyone!
Patrick
