I have a 2015 T770 bobcat that has an electrical issue with the hydraulic release on the bob tach. It keeps blowing fuses and does it even if your not using it. I have taken it to the dealer and they changed the wiring harness that goes under the engine but did not solve the problem. They said it is probably in the main wiring harness somewhere and no way of locating where so I would have to replace the whole harness which isn't very cheap. Just wondering if anyone else has had this issue and may have a solution or where in the harness it might be. there are no nicks in the harness anywhere and all of the hard casing is still intact.
