TAK TL140 STILL LOSING POWER DOWNHILL
jimpad
ky
Does anyone know the purpose of the "to injection pump (in)" line. My latest theory is when downhill, the fuel pump pulls air from the tank via the "injection pump (out) line, through the pump and then through the "to injection pump (in)" line.tl140fuel.PNG
heymccall
Western Pennsylvania
First off, that drawing ain't right.
Fuel flow should go...
Tank bottom to separator single banjo.
Separator double banjo (a) to lift pump in.
Lift pump out to fuel filter in.
Fuel filter out to injection pump in.
Then, injection pump out to separator double banjo (b).
That book drawing only shows one connection to the fuel filter.
jimpad
ky
Separator double banjo (a) to fuel filter in.
Hmmm, where's the lift pump in that description? And the return to tank line?
jimpad
ky
I was thinking the fuel filter housing is integral to the pump so no outlet shown?
jimpad
ky
Does your manual show a similar picture to the one I posted?
jimpad
ky
well I put a check valve in the return to tank line. Ran great for an hour all downhill then **** the bed again.
jimpad
ky
Still fighting this problem. Took the fuel filter off today and it is not full of fuel... actually looks like the level is at the bottom of the threaded nipple that the filter screws on to. Does this seem correct? I would've expected the filter to be completely full.
jimpad
ky
So, if the suction is from the nipple, when going downhill the suction gets exposed to the air that's trapped in the top of the filter/housing. Going to loosen the filter and run the pump in the hopes of clearing the trapped air.
