Takeuchi tb 145 hydralic problems
Meronen
Sweden
Hi, I have a TB 145 and I’m having problems with the hydraulics.
All functions work except for the stick/stick cylinder.
I have tried adjusting the flow and replaced the seals in the cylinder, but nothing helps.
It works normally until the last meter, where it becomes sluggish and stops. After a few seconds, it jumps forward.
What could it be?
Ive not been so worried about this but now its starting to be more and more
Grateful for any tips.
Is the rod bent on the cylinder, or any imperfections in the barrel?
When’s the last time the filter were changed/cleaned?
Acting like a proportional valve is sticking.
Hffhvg
Slovenia
Can you measure the pressure at the cylinder? Might be port relief valve failing or in need of adjustment.
Meronen
Sweden
I have tried adjust the port relief, and i have also switched some hoses to other functions and still same problem
Hffhvg
Slovenia
I would still try to measure pressure at the cylinder. Adjusting the port relief gave no results because it may be broken. I believe you can try to swap the port reliefs from some other function that works well and compare results. But I have never done this. If you would do this you probably have to know what are pressure settings on them. You would probably need a service manual for that.
Universal Parts
china
Small-scale engineering parts distributor
Cylinder movement is slow and erratic. Without external force, the piston moves slowly and irregularly, like a creeping motion. This phenomenon is called "cylinder creep." There are three possible causes, which should be investigated one by one. 1. Air bubbles in the hydraulic oil cause unstable compression and release after pressure, leading to slow or erratic cylinder movement. Secondly, water may have entered the hydraulic oil, affecting its lubricity and fluidity, potentially causing clogged or sticky movements. Focus on the hydraulic oil first. Finally, a broken directional valve pressure spring can also cause this phenomenon.
Here is a video of the machine,
Now its running full rpm
Meronen
Sweden
I have made pressure and changed port reliefs but still same on the stick even if i swap, little confusee of next step
Meronen
Sweden
Thank you for your reply, i have changed the hydraulic oil total maybe 2weeks ago,
Gonna see if i can find out how to do with thid directional valve pressure spring
Thanks for your advice
Hffhvg
Slovenia
Then I would try checking the poppets and seats in the control valve, like you said yes…
heymccall
Western Pennsylvania
If the "slow then jump" is when the arm (stick) goes over center (hangs vertical), then there is a problem with the load sense to the pump.
I'll have to dig for the theory.
