Mrpush
Hi,
3rd time i popped a track!
Third times a charm! Pulling on track, i catch my thumb on
a sharp piece of metal under rear....fillet my thumb like a fish! Off to the ER I go, no work today or for 10 more!
Anyway, what gives with the grease tension-er and the front idler assembly?????
Front idler assembly falls out while i trying to get the popped side up slope. now cant get it back in correctly!!!
The rod and spring part are slightly bowed...and i dont think the pin is going into the receiver properly! does only the center of the receiver where the pin end goes push grease out? Impossible to "guide" it in with such tight quarters in the frame.
I'm beating the crap out of the idler trying to push it in w the bucket....I have the grease port open 2 full turns (manual say only 1.5 max) and im getting like almost no grease out!
I cant get the track back on if that idler is not fully back. What gives????
I have done this twice already same side, grease came out better and i could push idler in w bucket...not this time. and im on a slope in the worst possible spot. not getting machine out without both tracks on!!!
next, why these so bad on slopes???? maybe 15 degrees slope. POP off it goes again! First time my fault, I was on a slope and hit a small stump i didn't see which did it. 2nd time i have not idea...not on much slope at all...but was mounding soil in the track on downhill side...POP!
3rd time about the same but more slope. I was going slow, was not changing directions abruptly. POP.
I have it set to spec..about 3.25" mid gap as per manual. Do these thing just not do slopes well??? I can see the other track is ready to come off too...they shift laterally down slope in the middle...and the center rollers disengage...then..a little rock or to much movement and POP..off it comes! that is terrible!!!
now the track are about 50% and maybe they are worn more than I'm thinking on the inner steel lugs or something causing the pop offs???
Its my first Mini Ex so I dont know.
Any advice on getting the front idler in easily and correctly and why does the grease cylinder not seem to be letting out grease???
(also when filling it, as much grease as would go in would come out around zerk. thats 3 on this machine that do that. Grease gun in brand new and does all other zerks on other machines without leaks...making me think its the zerks on this machine not the gun.
Not much I can do for a week now till my thumb heals....can do this easy with two let alone one hand!!!
Any tips and tricks would be helpful!
Thanks!
MP
Thanks!
MP
