GrandpaScott
- Joined
- Sep 22, 2011
- Messages
- 35
- Location
- Minnesota
- Occupation
- Septic System Designer/Installer/Inspector
I have a first-generation TL-150 with ~2500 hours on it. A while back, I was having trouble getting it started and experiencing low power. A friend of mine ended up hooking up a "pull-wire" to something fuel solenoid related (it works, but I haven't even checked it out under the hood). The fix has been to put tension on the wire, and then when I turn the key to the run position, the wire moves about an inch or two, then I hit start, and it's all good. I tie the wire off, and everything is fine. I thought it was a fuel solenoid issue, but in googling the problem, it seems like it might be relay related. A few other symptoms that lead me to believe that are:
The alternator light flashes, but I don't think I'm losing battery power ever
I have no float on the boom
The above-mentioned reaction when I turn the key
I have been using the workaround for a few years, and even though it only takes about a minute to do, I'm probably losing time having done it a few hundred times instead of spending an hour or two to properly fix the issue. If anyone has any ideas for me, I'd like to face reality and take care of this.
Thanks,
Scott
Thanks,
Scott
