Takeuchi TL12 No Hydraulics (anywhere) after travel motor rebuild.
Georgia Iron
USA - Georgia
Not sure what you see working on electronic side, you should be able to test the coils without buying new ones
BB-Georgia
Hartwell GA
I'm not sure what that means ? I have 12v at lever lock solenoid and I can see it go to zero volts when lap bar is up. 12.6v when bar down position. I've tested voltage at lever lock mag switch too in cab.
BB-Georgia
Hartwell GA
Good Morning,
Just an update (no fix yet). Lever lock switch tested and functions. Lever Lock relay tested and functions. Lever lock solenoid replaced with new OEM and functions (magnetizes with lap bar coming down). Lever Lock Solenoid was replaced as a function of the parts canon being deployed not because the original wasn't magnetizing. I just wasn't 100% sure the original solenoid was working enough or properly. Still no hydraulic action on any function and it doesn't seem to be Lever Lock related. I'm not really what to focus on next as all of my Google and Forum searches point to Lever Lock related parts and systems. Any advice is appreciated.
Also the Lever Lock relay is the one circled in yellow up above in earlier post. The one circled in red is the travel speed solenoid. Lever lock solenoid for this TL12 is part number 1901748114
Brian
Georgia Iron
USA - Georgia
Good Morning,
Brian
Since you are saying the lever lock is working you need to confirm if the pumps are turning?
Take your gear pump on the front loosen it up with the bolts and slide it out a little so you can see if the shaft is turning while the machine is on. look to see if you can see it spinning. If it's not the engine coupler is broken.
BB-Georgia
Hartwell GA
It was a little tricky to do without making a giant mess of hydraulic oil but I was able to get the gear pump moved forward enough to see the shaft. Bumped the key and the shaft is spinning for sure. I also checked the main suction filter and pilot filter and they are both clean. The filters are less than 100 hours old but I thought I should check them anyway. Thinking about draining and inspecting the Hyd Fluid tank. I definitely get oil at the pumps as I get oil out of bleed ports or test ports but I don't have a good way to make sure the volume of oil is sufficient.
Georgia Iron
USA - Georgia
I spoke to a mechanic about it. He thinks it is still in your lever lock or wiring to it.
BB-Georgia
Hartwell GA
So as of last night here is where I'm at on this project..... Lever lock switch and relay working. Lever lock solenoid replaced (parts canon), 2-speed solenoid replaced (parts canon misfire), hydraulic filters inspected (clean and less than 75 hours on them). Hydraulic tank drained and inspected. Clean with about 4-8 ounces of water at bottom. Screen looked fine on endoscope camera inspection. Replaced gear pump assembly with new OEM unit. Replaced hydraulic oil with new.
Bucket and Arms now move. No travel at all. Left or right track forward and backward nothing. Opened both bleed screws on top of the main HST Hydraulic pump and there was some air (not a ton but some) and one of the chambers had some cavitated oil in it. These chambers were previously full to the top before all of hydraulic oil was drained out and gear pump came off.
I haven't had time yet to check any pressures on HST pump or fully troubleshoot with more bleeding. Ran out of time and energy last night. I'm hoping it is more air in the system or something simple as I really don't want the expense or time of a new HST pump (I'm scared to even think how much $$ that is)
Thoughts or suggestions on this sort of "new" problem?
Thx
Brian
Georgia Iron
USA - Georgia
It sounds as if you found one of the problems. How did you figure out the old gear pump was not working?
BB-Georgia
Hartwell GA
Good Morning
I tested for pressure at various places the workshop manual indicated always had 0 psi. Then I decided to test right at the Gear Pump. It was the mid section of gear pump which is for the bucket and boom, etc. but is part of gear part assembly. Had 0 psi on gauge right at output hose. Then took the gauge off and just had an open 1/8" test line. I would say I had 3-5 psi maybe and very little volume. I was prepared for a shooting stream of oil and it was more like drool. I don't really see how a machine with 2700 hours lost a gear pump and had 0 psi at all. Maybe thats how gear pumps fail????? All or nothing??? Tank and oil looked great. No metal or glitter and clean filters/screen.
I just ordered some fittings to adapt my test kit to the charge line that the manual says to test at on the HST main pump. I won't have those fittings until mid or end of week this week most likely. I have lots of NPT and 37 degree JIC stuff on hand for agricultural and construction type implements but this machine is mostly BSPP and I don't really have any fittings in that flavor on-hand.
Georgia Iron
USA - Georgia
How much coin was the new gear pump?
Hopefully your travel pump works right after rebuild. I had two drive motors rebuilt, all the labor to put them back in and they both failed within 4 hours. I ended up needing to by new ones and do it again.
Makes you wonder if they put the wrong fluid in when something blew.
BB-Georgia
Hartwell GA
New gear pump was almost $1600. I hope the one travel motor survives the rebuild. The darn floating seal was $560 so that would be a quick $500 down the tubes and a bunch of time if the drive fails. I'm just hoping my HST pump is OK. I'm scared to think what that costs.
Toddgarage
S.E. Michigan
Construction, welding/fabrication, operator
All of us have been here before. You make a repair to one system and something else fails. I’ve worked on the TL130 , 140 TL8, 10. All very similar machines.
Options:
Bleeding air from the system. I’ve had other technicians explain the pilot controls as low pressure brake lines. If there is a big section of the pilot hydraulic circuit with air trapped, it can cause troubles. (Air in any hydraulic circuit is bad). Some systems will expel air slowly on their own, internal leakage, relief valves, etc. Some need to have a line cracked to get out the air.
I’ve found the wiring on these Takeuchi’s to have issues from vibration. Look for damaged wiring. Give the wiring harness a wiggle and see if problems come and go.
Check the fuses with a meter. Make sure the power is going through it. I’ve had more than a few fuses look good to the eye, but not work because of a tiny break in them.
Be careful. Having the cab flipped up, and the lap bar engaged will allow the hydraulic system to work. An accidental bump on a joystick could cause that function to work. None of the Takeuchi machines I’ve worked on have a cab safety switch.
BB-Georgia
Hartwell GA
Good Morning
I'm a little embarrassed but the cause of the issues has been discovered. I'm not sure why replacing the gear pump got Aux hydraulics and Boom/Lift, etc working. Maybe the original pump was a little weak and replacing it with a new one helped? That being said the main cause of all of this is the rebuilt travel motor. It is leaking or bypassing internally and not allowing charge pressure to build up. If the rebuilt travel motor is taken out of the equation with caps on the lines, everything works and the pilot pressure warning alarm goes off.
I'm not sure if I can find a professional to disassemble and reassemble the travel motor but it needs a pro to spot what we did incorrectly during our reassembly process. It does have a new $560 floating seal and other misc new o-rings. All of the hard parts were in really great shape too. I hate to walk away from it but at this point I need to shell out for a ReMan unit and get the machine going. Maybe have my OEM travel motor fixed later?? I should have eliminated the travel motor from the equation way earlier but I was unaware that it could leak like that internally and cause charge pressure to not build for the entire system. Live and learn I guess.
I'll post again with the final final fix but for now I wanted to let you guys know what the real Gremlin was.
Brian
Arny L
canada
There's nobody on this form, that hasn't been in your shoes, and gone down the wrong rabbit hole.
