Hi everyone, I would appreciate your thoughts on potential causes for oil getting in the radiator on a TD70G.
It previously had overheated and got a small crack in a cylinder head that caused overheating and pressure in the radiator (which I've heard is a common issue with that engine). I had the cylinder heads rebuilt, and that head repaired in a specialized shop (with oven etc).
After a couple weeks of light use and then a half day of heavy use, it overheated with 'milkshakes' coming out of the radiator overflow. When restarted a week later (for less than a minute), the radiator was not showing any pressure (eg cylinder head crack), but fresh oil was flowing in.
Does it sound like an oil cooler problem or any other thoughts? Thanks!
