Thank you so much for that. The hydraulic oil level is ok on it. Could the sensor be bad?Hydraulic Oil Level - https://www.iso.org/obp/ui/#iso:grs:7000:1412
The main link shows all the ISO 7000 pictographic symbols for equipment - https://www.iso.org/obp/ui/#iso:pub:PUB400001:en
Possibly. It’s also possible that you could have a wiring harness fault.Thank you so much for that. The hydraulic oil level is ok on it. Could the sensor be bad?
It was the harness. Do you know where I can get the service/repair manual for this machine?Possibly. It’s also possible that you could have a wiring harness fault.
Glad you found the problem and sorry I have no idea where you could get a manual.It was the harness. Do you know where I can get the service/repair manual for this machine?
Thanks to you for letting me know what the symbol was I was able to. Oh alright. I will keep on searching for it.Glad you found the problem and sorry I have no idea where you could get a manual.
If you use this link it takes you to all the symbols and you can figure it out for yourself. You need to scroll down and click the "Show All" button to get the full list. The one for the hydraulic oil level was a fair way down the list IIRC.That symbol came on today. What does that one mean?
It has a Allison.Hi Brian,
your TA 40 got a ZF or Allison tranny?
Yeah, I searched it like three times and could not have seen it. I appreciate your help and that link as it will come in handy in the future.I looked at the ISO 7000 list as well (more than once) and couldn't find it which is strange because I was under the impression all manufacturers were obliged to use those symbols and nothing else.
