Scotty Brown
Hello everyone. I recently bought a 99 Terex 1048 with a Cummins B3.9C. It was running fine when I bought it 2 weeks ago. Sent a truck to pick it up (700 miles) and it wouldn't start. Between the time I bought it and sent someone to get it the temps dropped to about 16 degrees and the block heater wasn't plugged in. They thought it was cold so they plugged it in, but that didn't work after almost 2 days. Thought it was out of fuel so they added some and bled the lines. There was air, but still no start. The mechanic that bled it is stumped. I'm told there's black smoke while turning over still. One person is convinced the motor is shot and needs overhauled. However, I've never experienced an engine going from running to not after sitting a week because the motor was shot. I understand being more difficult to start when cold, losing power or excessive blue smoke, but that didn't happen. No warning signs as far as I know.
One thing I remembered from my previous Terex telehandlers was that it has a pump off button to disengage the hydraulic pump when starting cold. I don't know if they tried it or if it would even make a big difference. It had not been used a lot before I bought it, but it was started and ran fine just before.
Does anyone have any ideas? Something we're not thinking about? Do you think the pump off would make a difference? Again, I'm trying to do this from 700 miles away. THANK YOU!!!
