It is a regular event on HEF for someone to post a question regarding Cat machine electronics, Diagnostic Codes, etc. For a large number of the questions posted the answer(s) revolve around the famous Cat “Click Box”, otherwise known as the 4C-8195 Control Service Tool.
This tool usually hooks up to the machine Diagnostic Connector, and by grounding different connections in the electronic system, transforms the electronic dashboard of a machine into a Diagnostic & Calibration screen.
After talking to some of the other members I would like to take the opportunity to start to create a thread to pull together information about the Click Box, for example: -
· How it is built, including a DIY version that you can make for yourself.
· What it is designed to do.
· How to use one.
· Tricks, Tip, & Traps about using it.
· Extracts from Service documentation for common models.
Please note: This thread is NOT designed to be a place where you can post your questions relating to specific diagnostic procedures. Think of it instead as a library of information regarding using the Service Tool.
Please post any diagnostic questions by starting a new thread in the appropriate forum for your machine. It may well be that a member will link to this thread when answering and that’s how it’s designed to work.
· How to use one.
