We have a 287C with MTL undercarriage. We have just shy of 1600 hours on the original, and it is time to start thinking about replacing it.
We do stream channel restoration and construction work and the 287C is used to shuttle materials (rock, root wads, etc.) to the excavators when conditions prohibit the use of a loader. Hence the poor skid steer encounters nasty deep mud when temperatures are below freezing. No matter how much time one spends cleaning tracks at night it is rare when all the bogeys roll the next morning, hence taking a bunch of time and effort to get everything moving the next morning. My only complaint with the OEM undercarriage is the use of the rubber lined bogeys and idlers, as we cannot use a weed burner to quickly warm the metal up and free everything as we do with excavator carrier rollers.
I have a quote from Bair products to replace all the bogeys, idlers, sprocket bushings and bolts, and tracks. The bogeys and idlers are made of smooth sided metal alloy and should make morning start up much easier and quicker. I believe that I will go this route but wanted input as to the quality of the Bair components, especially the tracks. Our original tracks have a few small cuts and rips, but are still very functional and the tread depth for 1600 hours is excellent. I am tempted to get the OEM tracks from Cat, but all the bogeys and idlers from Bair as Cat still doesn't have a non-rubber lined bogey.
Have any of you had good or bad experience with the Bair products?
Thanks
Thanks
