Turbo21835
Hello all. I am currently laid off and am spending time at my unions training center. I have been around dirt work for 3 of my 5 years of operating equipment. Started out on scraper, and also checking grade on a finish crew. Then move to scraper operator on a bulk crew. Next came push cat operator. Spent 3 months with a D5C doing finish grading around houses and a couple of road projects. I have spent some time at the school with a dozer refreshing myself with grading. This week I was on a grader. Cat 140G to be exact. Some free handing, some with GPS.
The instructor has told me I have great potential to get a full time seat in a grader. He said if I am able to spend the winter with him there is no reason I shouldnt be able to go after things next spring if I can find a machine. That may be the hardest part of all this.
So heres what I'm looking for. What kind of things should I be practicing. I've been working on rough grading cut and fill areas. Ive been cutting flat bottom ditches. Using the material from the ditch to build a 50ft wide roadway. Ive also graded a "football field" and graded an area for drainage with GPS. What other things should I look at doing while I have the time. This week I'm looking at grading a street into a culdesac, Grading berms and slopes, Grading streets to curb lines. Ive seen some tricks done with a grader that I couldnt believe. Most of them done by Randy Kreig. Most impressive was pealing asphalt out of a 4 inch wide trench, done for an electrical contractor at an airport.
Josh
Josh
