EskConstruction
Hello and thank you for the help in advance. I have a TL 140 with 2200 hours. Recently it started the whole runs and dies and then stays running. I got that fixed air bubble in the upper hose.
Now it runs for 30 seconds and dies. While doing this the low coolant and oil light flashes and when it shuts down the orange triangle flashes and the motor dies. Everything else works when it’s running.
I changed the low coolant sensor with no luck. I have not changed the oil pressure sensor yet. However I did find the bypass wires everyone speaks of. Plugged them in and it fired up and stayed running. I didn’t notice any strange engine sounds sounded like it always does.
My question is what did I bypass?What am I missing? Also the temperature gauge doesn’t work. Would that have anything to do with it? And the obvious has been checked coolant is full oil is full. And I’m doing a full filter change on it as well. Any help is appreciated.
