I have a 2006 tl150 open station. Randomly it would not die simply by turning key to off position. Fuel pump would remain running until battery was disconnected. We began killing machine by under powering it against an immovable object. After battery has been disconnected machine will start and turn off between 3-4 times before the issue reoccurrs. Replaced the ignition switch as it was believed to be bad. Problem continues after that. It would seem that a fuse/circuit breaker or relay is resetting with the power disconnected and it begins working until tripped. I'm not finding anything on a breaker of this kind. Help is much appreciated
