Not this time. I have to hold and oppose, since the line is just clamped to the boom and I could kink it of I go after it without backing it up. I tried a few love taps and the line was bending precipitously!
Take and hit the flats of the outer fitting nut a few licks with a hammer even if you have to back up the other side of the fitting with another hammer then she will turn loose.Not this time. I have to hold and oppose, since the line is just clamped to the boom and I could kink it of I go after it without backing it up. I tried a few love taps and the line was bending precipitously!
Alright, I haven't messed with something so enjoyable for a while. I got home and straight away set up the laser, watched 3 LightBurn (the recommended software) tutorials and got on my merry way. Ended up screwing around for about 7 and a half hours drawing different stuff and experimenting. I expected the learning curve to be much longer than it is as I made several engravings that I'm thrilled with, as first attempts. This is very exciting to me and I can see big potential for using it with who knows what. These were done on two different materials, a very small sample sized piece of plywood they send with the laser (I cut holes in it! Probably 1/8" thick) and a piece of cardboard/pressboard stuff I have covering my workbench. The only real problem I have so far is that the entire machine jumps around a bit as it moves. Slowing the machine down helps a lot but I'll have to figure out a way to bolt it to a stage of some sort.
I started off just printing random stuff on the cardboardy junk but it engraved beautifully. You can see just shapes drawn in the software, then two pictures, the little tree is a close replica to a tattoo I have and then the dark stuff near the top right is a map of my neighborhood, that one is blurry due to the machine shaking. Too cool!
Watch wes work? I like him too and saw him using the spark testerIt's been awhile.....I watched one of my favorite YouTubers use one of these ignition spark tester and had to have one.
It's a Lisle brand tool. I always thought their tools were pretty good quality. Now I just need to organize the shop well enough to easily locate it. Previously it was always a old/spare spark plug.
They are made for an angle grinder and you need the right backing plate and/or inner and outer arbor and nut. Not sure why they say for portable saws and show a small angle grinder??? Be very careful not to flex them or let them get stuck. They will shatter and pieces will fly. Wear a face shield. Metabo merged with Hitachi but the good Metabo grinders have a slip clutch and are top of the line. The discs you bought are 6in. which may limit your choices of grinders. Some grinders are 5/6in. and come with guards for both. You want a guard so you don't slice your fingers off. The good thing is I don't think there is a cheap grinder that uses 6in. discs. Dewalt, Makita, Metabo, Walter(made by Metabo but have an exclusive model with anti-vibration) tried a demo at a Walter training session. It was the smoothest grinder I've ever used but not sure you need something like that for occasional use. Some grinders have soft start and even variable speed but not sure if you need those either.
What ever you get make sure it is a 6" those are set up for the cutting wheels. Keep the guard on it .Great explanation! I have been using them for years incorrectly; take the guard off a smaller grinder and cut with an unsafe piece of equipment. Largely because I didn't know Metabo's existed until using them at a professional shop.
I am really interested in one with a slip clutch and soft start. Those sound like great features. Are you implying that all (or most) 6" units with those features are made by Metabo regardless of brand selection?
One other feature I liked about those Metabo's is they would shut down when they overheated. This was a fail safe to keep them from melting. We would take multiple units to a job site. When one shut down from heat we would sit it to cool for a couple minutes. We really beat those units up and they seemed to last.
X2 for the Walter Zip discs. But i bought one of these the other day to try. Seems ok so far but time will tell.View attachment 241046 it has to last 4 times as long to be cost effective but the other advantage is that it doesn't decease in diameter as it wears
