The lugs are 1/2" base is 3/4" box section on the lugs is 1/2" gussets on the shank are cut from a chunk of hollow structural tubing.The shank is 1 1/4" .All mild steel just because its what i had around the shop.What thickness material did you use for the base and the ripper it self? Looking to build one for my Deere track loader w/backhoe attachment.
A brand new 12" bucket from CAT was IIRC $1450. I called a used equipment dealer and they want $1150 shipped for the same bucket in well used condition.Wow, I wish I had a wishing well like some folks do. What would a new cat bucket cost? Wild guess
$10K ? That is such an easy fix for such a small fraction of either a new or used bucket.
I have in the old days fixed buckets in way worse condition. I can't believe someone wanting to replace it with a new one. If fixed correctly it will be stronger than a new one.
It is a compromise from going to a ripper or a 12" bucket, but as a digging bucket I find them a whole lot more versatile. 12" buckets are notorious for sticking material. If it has any grab at all you are filling them up and banging them out all the time. The 18" seems wide enough to self clean a little better. I think it will make a fine prybar.Well just got off the phone with a sales guy at my local CAT and he said he found the same style of bucket I have now but in an 18" width at a store over in Idaho. Should be here Friday. Said it's used but in good condition, $750. As long as it uses the same tips/teeth that I already have on the shelf I'll probably take it. He quoted me $2000 for a new 18" CAT Rock bucket which seems to look very similar by the pictures. About the same specs between the two, the rock bucket outweighs the heavy duty bucket by 30 lbs. 285 vs 305.
In looking at what specs I could find online some of these aftermarket buckets are weighing quite a bit more. I'm wondering are they using lesser steels? So they are thicker and heavier, but the strength might be about equal? My broken 30" CAT heavy duty bucket shows a weight of 368.2lbs a bucket I was considering from AIM an 18" shows a weight of 432lbs. For a bucket nearly half the size.
Anyhow the 30" lasted me pretty good considering the abuse I put it through. And I'm assuming the guy I bought it from had it on there since he bought the machine in 2014.
Seems like this 18" for $750 is worth a shot.
I was thinking the single tigers for getting into rock.Yea nice bucket for 750. I would agree, it likely came on a new machine and was traded out for another bucket. I like twin tiger teeth for frost, not a big of fan for rock and least the lava/basalt we have, they don't hold up for that. The single point teeth (Star) work better for rock and concrete, and least in my experience. Either way, this bucket with some specific teeth will be much better than the 30" bucket you were using.
