I picked up a D65P-8 Komatsu at an auction to do some work around the farm. The previous owner said it was a good running machine that he just replaced the steering clutches in & the brakes needed some adjustment. I picked up a manual, adjusted the brakes, checked the fluids & took it for a test drive.
Now I am not a dozer operator by any means but have operated all types of equipment over the years so I have a very good feel for machinery including some old manual tranny dozers. This machine dosen't seem to push like it should. I removed one of the floor plates & can see it is the torque converter that is slipping. I am running the engine wide open & it dosen't seem to lose many rpm's before it stalls the tracks. It will push a load of loose dirt ok in 1st but won't cut much compacted clay. When I'm rolling across the field in 3rd & pull one of the levers to steer it, it will start to turn then come to a stop.
When I tried to check the pressures on the converter I got 2-6Kg/cm2 on the output side. The pressure rose as the rpm's did. Service manual says 2-3Kg/cm2. I could not remove the input test port. This makes me think there is a restriction somewhere downstream? Would that cause the lack of power or do I need a $10,000 converter?:Banghead
Any suggestions would be greatly appreciated.
Twisted.
Twisted.
