I was inspecting my JD350 tracks, in anticipation for grouser repair/replacement, and I measured the pin & link wear. The pins are under 25% total wear(over 75% left)when measure across a 4pin span, but the link wear is at 75%.(3" when measure from grouser to bottom edge)
How fast do links wear under normal use? Are they alot slower than pin wear?
Can I run these links out too 100%. I hate to rebuild the tracks when there is so much life left in the pins. The sprockets are very good shape too.
I've the feeling that the old links and grousers where fitted with new pins when they also should've been changed out, but what to do now?
Opinions?
Opinions?
