australian pete
this is what i did between new year and christmas, a late rush job to grind waste timber at a local tip, they wanted it fine enough to use as litter/bedding in a chicken shed, ground it 3 times, was nery dusty
Just remember these forums reach world wide and terminology from different regions may be different than where you are from.
Nice pics!
Nice Magnum you got there, 500ps?
Would be nice with some more pics of the truck too..
Nice pics. Not to nit pick but wouldn't that be more waste wood rather than waste timber? I meen timber isn't pallets or doors. Timber is logs, stumps, and brush, isn't it. Still nice pics though.
G'day Pete , that grinder should be able to get carbon credits . It truly is good for the enviroment , being able to recycle waste timber like that is terrific . It does'nt stop there even , after it has been used for bedding it can be put through again to make compost , awsome . It is obviously paying it's way . How much maintanance does it require and what sort of running costs do they have ?
Down here in Arkansas if it's bigger than a Board a few people will call it a Timber. A lot of people call skids timbers too.
Personally If it is around 2 feet long I call it a block, around 4 feet long then it's a skid, then a Tie and if it is over Tie Size then it's a Timber.
If I had a 6 foot long piece of tie laying around I would cut 2 feet off of the end and have both a Block and a Skid in order to avoid any confusion.
roddyo, im not that organised mate, i may call it, wood, timber, heads, stumps, logs, barrels, crap, trash and depending how tired/cranky i am some other names that i doubt i can use here.
i knew it was good, ( i grew up on a dairy where my father used it ) although i did not know all the technical stuff, im feeling greener and greener,seeing as i dont like greenies i may start to dislike myself, i won another job today grinding waste timber/wood in a tip. i guesss the carbon footprint the 16 litre cat engine in the grinder evens it all up.
Did you ever Feed Chicken Litter to your Cattle?
i guess your correct, probably doing more than most greenies.even though i do it for money i have to say i do get a kick out of what i do when the mulch is recycled in a beneficial way.Pete, I would say you are doing something real for the environment....
Great pics thanks for sharing.
Next thing , you'll be driving a VW Kombi van .
