cfherrman
Thing has sat for a few years but was running, not good, before being shut down. I have not seen it run. I've cut the frame behind the cab. Cab and wiring is not great.
1991 Pete 377 with Cummins lta 10 330 HP celect I believe.
I have a fuel primer, hooked into the fuel filter suction on it and have circulated fuel around. The suction fuel goes through the computer and I have unhooked that to make it easier to prime. This primer will run my N14.
From the fuel primer I have confirmed that the fuel shutoff is working.
Have 12v to both of the fuses for the computer. I have a jumper wire to the back of the ignition to turn the cab and computer on.
Sounds over nice and will fire on ether.
There is no code read port I can find, there is a white twisted pair by the fuse box that's kind of weird.
Anyone know if this is the code read port? Any tips?
