Can't find the original post, but here's the latest update on the saga...
Tackled a job I has been putting off. Waranteed set of tracks have been on the shop floor fer about 2 months or more, just wanted to get the last inch of wear outta the old ones, cause I'm cheap! Anyway, for those not familiar with the story, bought a new tracked mower, feb 2019, everything worked fine, till I followed the instructions on track tensioning, long story short, I made it too loose. Later I tightened it up, but the damage was done. So Sunday, started about 10 AM, pulled the half sprockets off, and loosened the 8 bolts holding the torsion axle on, and replaced the tracks. Got it all buttoned back up, and the national anthem was playin on the radidio, so's I know I had most of 2 hrs in it. This time I put the tightening shims in, before mounting the tracks. its kinda like a shot in the dark, to guess shim thickness, without havin the tracks mounted, but it worked perfect, this time! Anyway, went out fer a test mow, mowed from 1PM-3:50, and it run like a striped ass ape! guess I finally got her licked!
